Message 1 of 4
BT Cloud
I am unable to purge a large number of deleted items from BT Cloud.When trying to empty trash and deleting ALL..I obtain the message .....Something went wrong..Trash is not available at this time,please try again later.Same message for last 2 days
However you can purge individual items though not all.No use when trying to remove hundreds of items.I have tried this through a browser,android and ios.All with the same result.
I know BT says it will delete all files from 31 October,however I wish to have piece of mind that they are removed,particularly as BT Cloud has been beset with problems since the closure announcement.
3 REPLIES 3
Message 2 of 4
Re: BT Cloud
Hi @earlset,
Welcome to the BT Community
I will send you a private message to get some details from you for our BT Cloud team to take a look.
Alex
Message 3 of 4
Re: BT Cloud
Alex. Unable to respond to your message as it was truncated and no reply button
Message 4 of 4
Re: BT Cloud
@earlset I received your private message thanks, I sent a follow up message if you can please reply when you get a chance.
Alex
