I'm trying to update to Norton on my laptop.
I've checked I'm an Account Holder and my BT ID is the email address on my account.
In security The BT Virus Protect tab has changed from 'Switch to Norton' to 'Manage' but just keeps coming up with ' Server Error'.
Solved! Go to Solution.
Hi, @HelenS1 I'm really sorry you're getting a server error when trying to update to Norton, we're aware of this problem and working to fix it. Please can you try again later?
Neil
Hi, @HelenS1 I'm sorry for any inconvenience caused. This should now be sorted can you try again?
Neil
Thanks Neil, download and install worked now.
