Message 1 of 11
BT app
Every time I use the BT app I now need to log in each time and reset facial id. BT sends out emails for recent bills, which require all of the above. Never used to be like this. Expensive package with poor overview/access  to your account. Also no email address that you can forward complaints/issues to.
10 REPLIES 10
Message 2 of 11
Re: BT app
I’m having the same problem with check my usage but BT do not seem to respond to this. I have to ring billing to find out what time I have left on my international calling. Never used to be like this as you say. What’s going on.
Message 3 of 11
Re: BT app
Thank you for your reply,
Still not working this morning, don’t know if ever be back to normal.
Message 4 of 11
Re: BT app
I was just about to post a question with the same issue. The app used to work fine but in recent weeks it requires logging in again and resetting the pin every few days. I'm on Android. Any replies to this issue please?
Message 5 of 11
Re: BT app
Same issue here. App logs out and resets itself. On iOS
Anonymous
Not applicable
Message 6 of 11
Re: BT app
Same here, I have fingerprint log in, then it asks me to log in with email password.  If I go to check my products I have to log in to that page again, on my home page it says set up biometrics and it is switched off. Even though I originally logged in with fingerprint. Annoying when you have to sign in every time to different page .
Message 7 of 11
Re: BT app
Still like this in September - are BT ever going to fix their app??
Message 8 of 11
Re: BT app
Agree, don’t think this will ever be resolved.
Message 9 of 11
Re: BT app
I turned off biometric login a few months ago, so login using my pin now and so far I haven't had to go through the whole re-login procedure since. May be worth a go for anyone who has biometric login enabled.
FAO BT - is this a biometric login bug?
Message 10 of 11
Re: BT app
The previous update about seeming to have success with turning off biometric login (and using the pin instead) didn't work - I was prompted again to login a couple of days ago.
