Message 1 of 9
Bt android app
Bt android app keeps crashing and can't access billing details keeps saying - (something is wrong try again later)
8 REPLIES 8
Message 2 of 9
Re: Bt android app
Good morning @stevenhollingworth84!
Welcome to the BT Community 😊
Is it at a particular point when you're using the app that this crashes, or does it seem to happen randomly?
Have you checked to make sure your phone's software and the app are both fully up to date too?
Peter
Message 3 of 9
Re: Bt android app
Both upto date just always crashing after I accepted all cookes then the error message pops up all the time then app closes
Message 4 of 9
Re: Bt android app
Cheers @stevenhollingworth84, is it a particular page that's asking you to accept cookies?
I use the app myself and it's not a popup that I've seen appear when using this.
Are you able to view your details if you try logging into the browser version of your account too?
Peter
Message 5 of 9
Re: Bt android app
Yes can login login on the browser but not the app
Message 6 of 9
Re: Bt android app
That's good, @stevenhollingworth84.
Are you able to view all of your bills and package information successfully through this?
Also what make and model of phone are you using right now?
Peter
Message 7 of 9
Re: Bt android app
Samsung galaxy a14 yes i can pay bills through browser
Message 8 of 9
Re: Bt android app
Cheers @stevenhollingworth84, that's still a recent phone so there shouldn't be anything compatibility wise causing issues here.
If you go into your phone's main settings app, then select My BT, can you please ensure all the permissions are set correctly?
Peter
Message 9 of 9
Re: Bt android app
I've been getting this issue for a few weeks also. If you reject cookies on the BILLS section of the app the bills page loads fine but we shouldn't have to do that so the app clearly needs fixing.
I tried reinstalling the app and get the same issue and recent reviews of the app on the Google Play Store suggest other users are having the same issue.
