Message 11 of 16
Re: Complaint Letter: Ineffective Customer Service for Opt-WiFi Issue
@aristcc
I have asked the mods to see if they can help you opt in to BTWIFI
Message 12 of 16
Thanks for clearing that up @aristcc
I'll be happy to take a closer look at this so please check your inbox for my message and drop me a reply with the details.
Cheers
David
Message 13 of 16
Hi @aristcc, the wifi team has checked and the wifi is showing as open on the hub now. Please would you test and let me if it's working ok for you now or if the problem is persisting?
Cheers
John
Message 14 of 16
Can you help me contact the BT wifi team again? On Saturday, I attempted to bring my hub to a friend's house and plug it in for 10 minutes, which temporarily fixed the issue. However, tonight the bt public wifi is not active again. Thank you.
Message 15 of 16
Hi @aristcc
Thanks for posting back!
Sorry you're still having some problems.  I can see my colleague @JohnC2 is dealing with this.  He'll be back in this afternoon and I'll ask him to give you another shout then.
Thanks,
Robbie
Message 16 of 16
Hi @aristcc, I'm sorry that this took longer than it should've to fix. The Wifi team has now fixed this for you.
Cheers
John
