Message 1 of 5
My BT app
Hi,
any advice my BT app keeps saying we are working on the system at present. This has been going on for several days, I have deleted the app and downloaded again also cleared cache I think.
any help appreciated
4 REPLIES 4
Message 2 of 5
Re: My BT app
I had a similar issue a while ago which meant the BT App would not work properly but it turned out the issue was  caused because i had multiple legacy accounts so the solution for me was to contact BT via webchat to get the accounts sorted and now everything works perfectly.
Message 3 of 5
Re: My BT app
Thanks, I will try them.
Message 4 of 5
Re: My BT app
Sorry for the late reply. Thanks for your help
Message 5 of 5
Re: My BT app
You are welcome.
