Message 1 of 7
My Norton
Does the new My Norton include a firewall. I cannot see any specific mention of a firewall. This was included in the McAfee package.
6 REPLIES 6
Message 2 of 7
Re: My Norton
On ‎08-02-2022 11h05
Message 1 of 1
My Norton
If you have Norton installed. Look in UI / Settings, should get mention. Alternatively, UI / History / Show (tl), shows most of the facilities.TTS 2.gif
Message 3 of 7
Re: My Norton
Thanks, not easy to find but eventually got there.
Message 4 of 7
Re: My Norton
Could you explain the places to look mentioned - no idea what UI means or tl. Could these be shorthand for something?
Message 5 of 7
Re: My Norton
@disinterested  UI means user interface.
  1. Open your Norton device security product.
    If you see the My Norton window, next to Device Security, click Open.
  2. In the Norton product main window, click Settings.
  3. In the Settings window, click Firewall.
Neil
Message 6 of 7
Re: My Norton
Amazing - thanks!  A pity it isn't sufficiently clear for me to have found that unaided!!
Message 7 of 7
Re: My Norton
@disinterested No problem, I found those steps on the Norton support webpages
Neil
