Message 1 of 7
Norton virus protect download
How do I open the zip file which has downloaded onto my iPad?
6 REPLIES 6
Message 2 of 7
Re: Norton virus protect download
Use Google
How to open zip file on iPad   there are detailed instructions
Message 3 of 7
Hi thanks for the suggestion, i’d already tried to unpack the zip as normal but all i get is a logo for Norton - any other ideas?
Message 4 of 7
Hi, @Rico66 BT Virus Protect is not available on iOS devices, however, you can use the Norton Password Manager on an iPhone or iPad.
Neil
Message 5 of 7
Thanks Neil is it likely to become available on iOS?
Message 6 of 7
Hi @Rico66 I haven't heard if there are any plans. I own an iPad and iPhone and have never installed antivirus as Apple have their own built-in protection. If you google do you need antivirus on an iPad you'll see the general consensus is no.
Neil
Message 7 of 7
