Message 11 of 22
Re: Not able to disable BT Web Protect
Hi @sonoma ,
Thanks for the post. We have your message and will get to you in turn. We're really busy at present but once you're at the top of the queue we'll be in touch.
Cheers
David
Message 12 of 22
Thank you, David.
Anonymous
Not applicable
Message 13 of 22
I’ve been having the reverse issue since the last hub firmware update, I turned it off to troubleshoot a work VPN issue and now can’t get it to switch back on.
All details are the same, get the usual 2 hour message via app or website, but it doesn’t switch on.
Just flagging, no need for a swift response this time of year but it hasn’t worked for a good few weeks.
Message 14 of 22
Hello,
I have seen the message a week back that my issue has been picked up, but unfortunately the issue has not resolved yet. Also, nobody has contacted me so far, please someone can have a look.
Message 15 of 22
@sonoma I can see my colleague has tried to call a few times. He'll give you another ring this afternoon.
Neil
Message 16 of 22
@NeilO thanks for your reply. I've not received any call yet though, anyway I'm waiting.
Message 17 of 22
Hi,
My issue is still not resolved and nobody has been contacted to me. This is really frustrating, thinking to move away now.
Message 18 of 22
If the mods say they have tried to contact you, they have tried to contact you. Do they have the correct number for you?
Message 19 of 22
Hi,
Yes, they have my correct number.
I'm giving you another number in private message, I'm available either of those numbers.
Message 20 of 22
HI @sonoma
Thanks for sending over those numbers, this is with a colleague who has assured me you will be called tomorrow on those numbers between 9am and 3.30pm to assist.
Stuart
