Message 1 of 7
Parental controls active when off
My parental controls are still blocking sites when turned off. I’ve never had an issue before but suddenly when I’ve turned off parental controls it is still restricting sites on all devices.
6 REPLIES 6
Message 2 of 7
Re: Parental controls active when off
Hi @Aprit There were problems with the Parental controls system in MyBT a couple of days ago but I understand these should now be resolved. Have you tried turning them on and then off again to see if that works?
Neil
Message 3 of 7
I have a similar problem - spoke to someone on Chat today and was told there were issues and I had to wait a week before this gets fixed.
Message 4 of 7
I have a similar issue - spoke to someone on Chat today and they told me I had to wait a week before this gets fixed. Seems a long time.
Message 5 of 7
Thank you for the info - do you know if it’s resolved yet as mine still seems to not work correctly!
Message 6 of 7
Hi, yes I’ve tried a few times to be honest and even tried different filter levels but no change! It just blocks everything . Hopefully they’ll sort it out soon!
Message 7 of 7
Hi @Aprit and @joannasa,
Thank you for posting. I'm sorry if you're having issues with Parental Controls not working. If you send me your details, I'll run a few checks and ask the Parental Controls Team to investigate.
I have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
