Message 1 of 7
Re: Parental Controls not working
Hello I have the same issue.
everything has worked correctly for years and suddenly nothing is being blocked.
can someone contact me please? I’ve tried all the forum answers, the telephone help but nothing works
thanks
6 REPLIES 6
Message 2 of 7
I have moved your post to this new thread, so you can get personal help from the community or moderators, so please watch this thread for updates.
Message 3 of 7
Hi @Paul45 welcome to the community and thanks for posting. I'm sorry you're having problems with your parental controls. Are you using a VPN or an Apple device with private wifi address or private relay features enabled?
Neil
Message 4 of 7
hi Neil
Thanks for quick reply. iPhone with private relay. Is that interfering?
thanks
Message 5 of 7
@Paul45 It can cause problems as parental controls can't identify the device via its MAC address, you could try turning it off on your iPhone to see if helps.
  • From the Lock Screen, swipe up to access the Home Screen
  • Tap Settings
  • Tap Wi-Fi
  • Tap the information button next your network
  • Move the switch to the off position, for Private Wi-Fi Address (iOS 14) or Private Relay (iOS 15)
Neil
Message 6 of 7
You’ve done it! Thanks Neil. That’s over a week of googling trying to figure out what’s going on.
thanks again
Paul
Message 7 of 7
Hi @Paul45,
Thank you for posting back. I'm glad that's working for you.
Thanks,
Paddy
