Message 11 of 19
Re: Virus Protect Widget removal
Thanks very much, @Paul862 . I followed your simple instructions and lo, the widget is gone!
Message 12 of 19
Please can you send me the instructions as well
Thnaks
Message 13 of 19
Hi,
Follow the instructions in my post at the bottom of page 1.
Message 14 of 19
The simplest way to remove any widget from an Android screen is: Press and hold down on the widget you want to remove until the menu that allows you to remove it appears.  This is an Android feature, and cannot be overridden by the widget!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 15 of 19
Thank you but I cant find the accessibility option in Settings
Message 16 of 19
Hi there @Robnash
Thanks for posting on the community.
Which device are you using?
Leanne.
Message 17 of 19
Hi Leanne, thanks for getting back to me. It is a Moto android and I am referring to the sliding widget hugging the side of the screen
Message 18 of 19
See message 14
Message 19 of 19
Senior moment.  Sorry I now realise the advice was to enter the phone settings not BT virus protect settings, so all good. Sorry for the confusion
