Message 1 of 12
Where is BT's Welcome Back department..?
And I'm not being sarcastic....
I want to know if I can come back to BT after making a very, very bad choice. My Hub5 downloaded at 52-54Mbps. Its replacement can only manage 37 (on the same cable). I intend to return it as unsuitable for purpose.
My last bill was on July 12, so I may still have a final payment to make. So can anyone point me to the Welcome Back department...?
NOTE: I hold my hand up to admit I did not read the info as carefully as I should and mistook the "you will get..." as "not less than". My bad!
11 REPLIES 11
Message 2 of 12
Re: Where is BT's Welcome Back department..?
I don't think there is a Welcome Back Department, head over to BT.com and have a look through the new customer offers as they're normally pretty good
Message 3 of 12
Thank you 🙂
Message 4 of 12
@Scotsmac
if you only left in July you are not considered a new customer  Try retentions and see if you resurrect your old account on better terms 08007831401
Message 5 of 12
Thank you - I'm terrible on the phone (hard of hearing - nightmare for both ends); is there a 'chat/**bleep** email' sort of link?
Message 6 of 12
The bleep was not swearing - I used the appropriate version of "come" 😀
Message 7 of 12
Come 😆
There is a live chat via BT.Com but I don't know what the availability is.... Your best bet is to look at what offers are available on the BT website
Message 8 of 12
The missus is on the way home, so I may get her as spokesperson 😄
Thanks again - I'll keep you posted.
Message 9 of 12
I guess you used a three-letter word that rhymes with "come" and indicates a dual purpose. Alas, it's also slang for a bodily fluid and offends this forum's hyper-sensitive, US-based provider. It idiotically censors numerous, perfectly respectable proper English words, the most egregious being a ban on blokes called Richard using the age-old abbreviation of their name beginning with D.
Message 10 of 12
If am accounts closed it can't be resurrected even if it closed in July, in that case the advice about joining as a new customer is correct
