Message 1 of 7
Does anyone know if you can pair 2 remotes with one BT TV Pro box?
6 REPLIES 6
Message 2 of 7
Re: BT TV
Hi @Highland_Tim, I've had a look at the information on the Pro Box and can't see this even mentioned. The only way will be try it if you've a second remote or maybe another member of the forum has already tried this and can answer.
Cheers
John
Message 3 of 7
Re: BT TV
Hi @JohnC2 @Highland_Tim  When my BT Pro Box remote was playing up, I tried my previous remote from the old box. It workedfine , and can work side by side.
Message 4 of 7
Re: BT TV
@JohnC2 OK thanks
Message 5 of 7
Re: BT TV
@scharter That's what I wanted to hear, thanks 🙂
Message 6 of 7
Re: BT TV
Only one remote can be paired by Bluetooth. The tv Box Pro will also respond to IR remotes that use the standard Humax code. So all the previous BT TV and Humax Youview remote controls will  operate the box if they are in line of sight.
Message 7 of 7
Re: BT TV
#zulu17
Thanks for the advice. I'll need to do a few experiments by the look of it.
