Message 1 of 9
Re: IPC6023 error on channels 300 upwards
I am having the same problem  but only with BBC 1 East HD (internet mode).
Last week I was getting an error message not having access to BBC 1 East HD. I rebooted the hub and did a box reboot and the channel came back. Since then when I record BBC 1 East HD I get the error message unable to show this recording and the error code IPC6023. I have followed the online guide and still no resolve.
8 REPLIES 8
Message 2 of 9
Hi @Jonty1964 and thanks for posting.
I've moved your post so we can look into this for you. Can you just confirm how are you connecting the box? Is it directly to the hub or via adaptors?
Cheers
David
Message 3 of 9
Hi
Thanks for your quick reply.
I am connected to the hub directly currently by ethernet cable. I had until this morning been wifi.
Message 4 of 9
Thanks for confirming that @Jonty1964 .
Can you give it a few days connected by ethernet and let me know if things improve?
Cheers
David
Message 5 of 9
I will do thanks
Message 6 of 9
I am still having the same problem. Did another test tonight. I recorded two programmes at the same time one on BBC1 East HD (Alan and Amanda Italian Job) and the other on 5HD (Cruising with Susan Calman). The 5HD programme recorded but the error message appeared for the BBC1 East HD programme
Message 7 of 9
Sorry you're still having this problem @Jonty1964 .
I'll be happy to take a look at this for you. I'll need a few details so check your inbox for my message and drop me a reply.
Cheers
David
Message 8 of 9
Thanks Dvid I have replied
Message 9 of 9
After speaking to a BT tech last week, the box was reset, a few other checks done, the problem I had has now been resolved
