Message 1 of 3
TV pro box Wi-Fi connection issues
Hi All,
Does the BT TV Pro box only connect over Wi-Fi to a Hub 2, or will it connect using whole Wi-Fi discs?
My Hub 2 is in a different room and over 5m away, I have tried to connect via WPS on Hub and disc (in same room), and using SSID and password. Other devices mainly Tv and AppleTv have connected seamlessly to hub/ disc.
When it try to connect via SSID and password, the “Restart connection” pops up.
My Hub2 has shown a 5GHz connection twice, but the  TV box states no internet connection and no apps.
I have tried all the usual restart Hub etc, so any help would be appreciated. Thanks
2 REPLIES 2
Message 2 of 3
Re: TV pro box Wi-Fi connection issues
I sent my 'Smart Hub 2' back as it is not as smart as the hub 6 I was using.
I had to switch off 2.4GHz on the 'Smart Hub 2' to get a stable connection with the Box Pro - but then other devices would not connect to the hub.
On the Hub 6 I name the two bands differently so can easily connect to 5GHz.
Message 3 of 3
Thanks, I’ve have sorted by using Ethernet port from Wi-Fi disc to TV pro box as less than a 1m apart
