Message 1 of 13
Are there issues with webmail versions of email - gone a bit iffy
So received a message about the changes on webmail. I can login on both my personal email and also on my email that manages the rest of the BT platform I use. I think thats the right terminology.
Sadly I was unable to log out of my management email and hence not log into my personal email. I seem to be logging in ok but the system gets confused when i log out. I was using this earlier and all was fine until the system was logged out automatically and I got the 3 page message that details the changes.
Not sure if this affects anyone else using webmail.
12 REPLIES 12
Message 2 of 13
Re: Are there issues with webmail versions of email - gone a bit iffy
Me too, unable to access my email and My Bt!!
Message 3 of 13
So this may not help you @Filosopher  but it seems to be working ok again for me. Since they have only just released it - i'm guessing that of course - I was logged in and it logged me out and forced their note regarding the new login rule (I use that term losely).
Anyway for the moment my system has stabilised - famous last words ... 😉
Message 4 of 13
I can only access my email via MyBt!
Message 5 of 13
@Filosopher what happens when you try to log in via the website? www.bt.com/email Are you getting an error message?
Neil
Message 6 of 13
Yes, user name and password not recognised. I can access them via My Bt or via my linked Gmail account.
Message 7 of 13
@Filosopher Have you tried a password reset on the email address?
Neil
Message 8 of 13
Now installed the BT Email App with a new password on all my devices.
Seems to be working so far.
Message 9 of 13
Working on iPhone and ipad via BT mail app but the app is not
compatible with my Mac Desktop!
Message 10 of 13
Hi @Filosopher there is no BT email app for Windows or Mac's as you should be able log in to BT email using a browser.
Have you tried logging in to webmail using in private mode?
Neil
