Message 1 of 4
BT Basic Email
With BT Basic email can you add an auto-reply, such as 'out-of-office'?
Thanks. David
3 REPLIES 3
Message 2 of 4
Re: BT Basic Email
I would suspect not as it is just a no frills basic email service which allows you to send and receive your email for free however perhaps somebody who has BTMail Basic may be able to check and report back.
Message 3 of 4
Re: BT Basic Email
Hi @davidwdirector,
This link will explain the main differences between our BT Email products.
To set an out of office message, log in, click on your email address on the top right hand corner of your screen and then click Settings. Afterwards, click on Mail which is on the left hand side and then click on Auto-reply. That should let you do it.
Any issues, let me know.
DanielS
Message 4 of 4
Re: BT Basic Email
thanks v much. David
