Message 1 of 2
Blind copy box will not recognise email groups
Since the layout changes happened the BCC box does not recognise email groups as set up in my group contacts list.
Is there a fix for that?
Tags (2)
1 REPLY 1
Message 2 of 2
Re: Blind copy box will not recognise email groups
Have a read through these threads and make sure you click on the Bcc letters not the address box.
Solved: Re: email contact groups not working - BT Community
Solved: Re: New Email System - BT Community
