Message 1 of 3
Downloading attachments
Since yesterday I seem unable to download attachments from BT webmail. I've never had this issue before. I tap on the three dots and see "save to device" then see a very brief blue line appear from the left of the screen that gets only about 25% of the way across, but nothing downloads. I can't see any settings that need changing and I've not actively changed anything either. Any clues?
2 REPLIES 2
Message 2 of 3
Re: Downloading attachments
Hi @legoman26, sorry you can't download attachments from webmail.
Are you able to test on another device to see if you can download there?
Cheers
John
Message 3 of 3
Thanks for the reply. I'll check later and report back
