Message 1 of 9
Why do some of my posts go to Outbox ?
8 REPLIES 8
Message 2 of 9
Re: E MAIL
Hi @Dave2810
Welcome to the community.
Are the emails that are going to the outbox then sending or are they stuck there?
Do you have your email in the BT webmail site, the BT email app or are you using an email app or client?
Michael
Message 3 of 9
Re: E MAIL hi some of my posts not all of them go into outbox.they are then stuck. I only use the bt
Message 4 of 9
Re: E MAIL
I use the bt mail app
David
Message 5 of 9
Re: E MAIL
Thanks @Dave2810
Can you try to delete the app, restart your phone and then install the app again?
It is also worth making sure that your phone software is up to date.
Michael
Message 6 of 9
Re: E MAIL
Better still, delete the app and install Blue Mail instead.
Message 7 of 9
Re: E MAIL
Job done thank you 😊
Message 8 of 9
Re: E MAIL
Thanks for the tip it worked  😆
Message 9 of 9
Re: E MAIL
That's geat news, I'm glad you're all sorted now.
If you need anything else, just let us at the Community know 🙂
Chris S
