Message 1 of 4
Email Problem
Hiya
Hoping someone will be able to help me
When i send an email to an individual everything is fine  but when i send it to a group of 6 friends it comes out as gobbility **bleep** for them so unreadable.
We have had our group email for over 5 years , same people, same emails, this only started 3 weeks ago, so i can only send emails to individuals now
This is on my lap top on bt web mail and on my phone using samsung email app
Help me please
3 REPLIES 3
Message 2 of 4
Re: Email Problem
Are you adding the recipients email address one at a time to the email or have you set up a "Group" with their email addresses and are adding them as a Group?
As a test, if adding as a Group can you try adding them one at a time to the email.
Message 3 of 4
Re: Email Problem
Thanks for your quick reply.
I add them as a group that i have had saved for years, so will try your suggestion of adding them  individually & see if that solves the situation
Message 4 of 4
Re: Email Problem
So I added them all individually and they received the email ok in a readable format.
Does that mean i need to delete the group  & make another one up or just stick to adding them all individually  every time?
Odd as ive been adding them as a group for the last 5 years with no problems until recently
