Message 11 of 16
Re: Email access
Could also be an IP conflict. Try unplugging router for 30mins, if no joy then yes Trust and Security need to be employed.
Message 12 of 16
Re: Email access
Hi @gdandbg,
Thank you for taking the time to speak with me today.
I'm happy that I was able to remove that prompt flag for you which allowed you to access your MyBT and emails through a web browser again.
If you ever need help, please, feel free to get in touch with me.
Thank you
DanielS
Message 13 of 16
Re: Email access
Thanks so much for your help, I really appreciate it. Happy New Year!
Message 14 of 16
Re: Email access
I'm having the same issue, stuck in a loop when trying to log on. it occurs when I try to check mail through both  Outlook and through browser, it just constantly returns to the log on screen. This happens even when I try to access mail when logged on to MY BT. What do I need to do?
Message 15 of 16
Re: Email access
Get in touch with the moderator, DanielS, as he sorted it for me. Also try the email app to bypass the problems with signing in. Hope you get it sorted.
Message 16 of 16
Re: Email access
Thanks, sorted now with tech support online. Not sure what caused problem!
