Message 1 of 11
Email login loop
Hi There,
I'm stuck in the dreaded login loop when trying to access webmail (and my password is being knocked back by my Outlook client).
I go to the webmail sign in page and use the same username/password i use to log in the main BT page and just get redirected back to the login page.
https://home.bt.com/login/loginform?TARGET=$SM$https%3A%2F%2Fsignin1.bt.com%2Fbtmail%2Fsecure%2Femai...
Can someone please assist (not much traction from BT support)? Have tried a different browser, machine, clearing cookies in existing, etc.
Thanks in adv.
10 REPLIES 10
Message 2 of 11
Re: Email login loop
Hi @AllyG47 and welcome to our community.
Sorry you're having problems logging on to your email. Do you see this on all devices?
Cheers
David
Message 3 of 11
Thanks. Tried on another device - no luck
Message 4 of 11
Thanks for trying that @AllyG47
Have you tried the forgotten password route?
Cheers
David
Message 5 of 11
Hi David,
Son of AllyG here!
Yes, we've reset the password multiple times - the problem appears to have started after someone had brute forced their way into his account and sent out multiple "scam" emails, and we were advised to reset the password and enable 2FA.
He's not been able to log into email since then, but can login to the main BT site with the same credentials. I have tried logging in on my own device (separate ISP) and get the same.
I can supply a .har file that show login success followed by redirection to the logout endpoint, if needed.
Cheers
Thomas
Message 6 of 11
Thanks @tomg47
@AllyG47 I'll take a closer look at this for you. Check your inbox for my message and drop me over the details.
Cheers
David
Message 7 of 11
It did not work.
Message 8 of 11
What didn't work?
Message 9 of 11
Thanks for letting me know this is sorted @AllyG47 . I'm glad I was able to help.
All the best
David
Message 10 of 11
Can't see the solution, I have been having a simiklar issue for nearly 2 wees, Have to delete all browsing data each time I want to access email or using a private window may be working. BT Support have been helpful, but can't find the issue, it's draining!
