Message 21 of 22
Re: Email not being receiving whilst on 4G
"If you can it sounds like your email account has been downgraded to a BTMail Basic account. This can only be used with a web browser and not using an email app such as you will have on your phone."
But the OP said that their phone immediately picks up emails when it hooks onto his house WiFi, so the email app on his phone is picking up his emails OH then. It just doesn't when connected via 4G, and I think the OPs later suggestion that it is just too slow to pick them up which is the problem.
4G speed (and indeed 5G speed) can be very variable, depending on the strength of the signal
Message 22 of 22
Email will work with 1 Mbps and the OP stated that the email worked when using a webmail on 4/5g as did using the Internet. The OP has now said that the emails work on 4/5g with the BTMail app.
Also as per message 18.
