Message 2 of 22
Is BT email down at the moment?
I get the error message in the attachment -
Anyone else getting this?
21 REPLIES 21
Message 1 of 22
Is email down agian
Trying to log into email it is saying:-   Is it down please
Hmm. We’re having trouble finding that site.
We can’t connect to the server at prod-btemailauth.bt.com.
If you entered the right address, you can:
  • Try again later
  • Check your network connection
  • Check that Firefox has permission to access the web (you might be connected but behind a firewall)
Message 3 of 22
Re: Is BT email down at the moment?
I rang them. It's down.
Message 4 of 22
Re: Is email down agian
I'm getting exactly the same. Please can someone advise what to do?
Message 5 of 22
I rang them. There's a recorded message. They're working on it.
Message 6 of 22
Yes I am getting the same error , both with my usual Firefox browser and the same when trying Microsoft Edge, but have been able to access via my  Gmail app on my mobile
Message 7 of 22
Did they give you any clue when we're likely to be back up?
Message 8 of 22
No. It says "as soon as possible".
Message 9 of 22
The Microsoft Outlook Ap on my mobile is still showing an up-to-date BT email inbox for my account. So, I can see new incoming messages that way.
Message 10 of 22
Yes I cannot log in using email.bt.com
nslookup gets: "dsldevice.lan can't find prod-btemailauth.bt.com: Server failed"
I was told 4 hours  @ about 17:00
My outlook can access my btinternet via imap
A test messge to myself arrived at my inbox
