Message 11 of 22
Re: Is email down agian
BT told me about adding btinternet to outlook as a work around a few months ago. That seems to be working.
Message 12 of 22
Re: Is BT email down at the moment?
It is only webmail that is down. It is working on email clients and email apps.
Message 13 of 22
I'm getting that aswell
Message 14 of 22
I understand it is a fault in the Microsoft 'updates' to the opening pages.......
I trust an expert will appear and explain the technicalities!!!
Message 15 of 22
It's broken. It will be fixed!
Message 16 of 22
  • On the BT Mail app when I hit Login to BT Email the screen swipes left then comes back to the same view without giving the option to put in your details. After uninstalling and reinstalling it is still doing the same. I'm also having trouble getting in to the EE TV app.
Message 17 of 22
The message from BT currently says
https://www.bt.com/help/check-service-status
We're aware of login issues with BT Mail on webmail and via the BT Mail app. You may not be able to login until this is resolved. We’re working to get them sorted as soon as possible. You can still access BT Mail via clients such as Outlook Express.
Message 18 of 22
The server at prod-btemailauth.bt.com is taking too long to respond
Message 19 of 22
Just started working again for me.
Message 20 of 22
