Message 1 of 7
LOST E MAIL FOLDERS HEEELLPPP!
Hi
Just transferred a load of extremely important emails into folder and now the folder has completely disappeared.
Looked everywhere.
CAN YOU HELP ME PLEASE!!
Trixiebelle
6 REPLIES 6
Message 2 of 7
Re: LOST E MAIL FOLDERS HEEELLPPP!
Log onto your email account using a web browser and check the trash folder. To the left of the folder there may be a small arrow . Click on that and with any luck your folder will be there. If it is just drag and drop it back to where it should be.
Message 3 of 7
Just done that and it only has 2 empty folders in there I created today - the bigger one with all the info nowhere to be seen!
Message 4 of 7
When you say "2  empty folders in there". Is that in the Trash folder when you click on the arrow or are they in the My Folders section?
Message 5 of 7
In the trash.
Just spoken to BT support guy and he said 'sorry, they're gone 😞
How can they just disappear??!!1
Message 6 of 7
What do you use to check your emails? Which client?
Roger
Message 7 of 7
Thanks for your help.
Now going for a lie down!
Trixie
