Message 1 of 10
1471 service - unable to delete a message
Hi, I have recently received a notification on 1471, to advise that I was called on a certain date / time etc.  On listening to the notification the only option I am offered is to return the call - option 3 (which I think is a scammer). 1471 does not accept any other option. How do I remove/delete  this please. TIA
9 REPLIES 9
Message 2 of 10
Re: 1471 service - unable to delete a message
@Robnash dialling 1471 tells you the number of the last person that called and gives you the option to return the call by pressing 3.
If a voicemail has been left you need can dial 1571 to listen to the message and delete it.
Neil
Message 3 of 10
Thanks that's exactly what is happening. I don't want to return the call. I just want to delete the notification
Message 4 of 10
You can't. Its just a notification of the last number that called you.
Message 5 of 10
That is really annoying cus every time I dial 1471 I get this and not sure if I can get any other legitimate messages for me. What happens if I cancel 1471 and then reinvoke?  Bt needs to stop this happening
Message 6 of 10
Sorry didn't read your message properly, I didn't phone them, they phoned me and I didn't answer and it went to 1471 with no message just calling details, how can I delete this please ?
Message 7 of 10
Arrange for someone else to call.
Anonymous
Not applicable
Message 8 of 10
Are you sure you mean 1471 & not 1571? 1471 doesn't take messages, it simply tells you the last number that called. You can't delete the last number that called as that would defeat the whole object. I can't see any reason why you would continually dial 1471 in order to be annoyed by this?
Message 9 of 10
If no one else has called you since this ‘scammer’ called , then ( obviously ) that is the last number that called you ( and that’s what 1471 does , reports the number of the last caller ) , if this numbers mere presence on 1471 is annoying ,and you cannot stop yourself from checking 1471 ,  call yourself from another landline or mobile , that way when you check 1471 the number read back will be the number you called yourself from, that is k until someone else calls you , and that number becomes the ‘last caller’
Message 10 of 10
Thanks and done
