Message 11 of 19
Re: Alarm dialer and BT Digital Voice VOIP
Analogue telephone adapter
Message 12 of 19
arhhh ok ..thank you
Message 13 of 19
hi did this solution work for you? i have issue with alarm dialler now not working after BT recently switched us to digital voice
thank you
Message 14 of 19
@gcwj and @karlos103
Hi - did either of you resolve this issue?  I have the same dialler (SD1+) and our BT network is being upgraded in the spring and I am being told I need to replace the dialler, though they seem to imply the complete security system which cannot be the case.
Any feedback appreciated.
Message 15 of 19
I have the same issue, cant seem to get a replacement dialler for digital line!
Anonymous
Not applicable
Message 16 of 19
@carystb
There is no such thing as a dialler for digital line. Your existing dialler will either work or it won't, only one way to find out.
Sadly, posters rarely revisit their threads with an outcome.
Message 17 of 19
My alarm supplier told be that my auto-dialler would not work with Digital Voice and I should upgrade my "obsolete" alarm system (ie, buy an new one from them). I decided to wait and see.
Once Digital Voice was up-and-running I unplugged the autodialler from the old BT socket and plugged it into the hub and it works just fine with no adjustments or changes needed.
I've also connected a multi-way socket to the hub so I can have the autodialler and home phone connected simultaneously and that works just fine, too.
The only thing that I have yet to try is the "remote control" of the alarm (calling in and checking or changing alarm status).
Message 18 of 19
Thanks for that info @grahamm1 - my auto dialler is very old so don’t think mine will work but no harm in giving it ago when I get swapped over.
Message 19 of 19
Unless your auto dialler is pulse rather than tone dialling, it won't matter how old it is.
