Message 1 of 8
BT HD phone won’t turn on
Hi all,
hopefully  someone can help.
we have a new but he digital phone and despite checking and changing batteries it still doesn’t t show any signs of life.
when I take batteries our and put back it beeps/flashes twice and then off again
any ideas?
7 REPLIES 7
Message 2 of 8
Re: BT HD phone won’t turn on
Is this a new phone for Digital Voice or just a new phone for existing copper. Connection?  Which model of phone?
Message 3 of 8
Sorry, that might help!
BT Advanced Digital Home Phone Cordless With Alexa Built-in Wireless Work HUB 2
i should also say that it was working but then seemed to stop as though the batteries ran out of charge but that was in just a few days
Anonymous
Not applicable
Message 4 of 8
Sounds like maybe the charger has failed or become disconnected. Not being familiar with that model does it show any sign of charging?
Message 5 of 8
Di you charge the phone for the recommended 16 hours before initial use?
Here's the user guide:
BT-Advanced-Digital-Home-Phone-wit-Alex-Quick-set-Up-UserGuide.pdf
RIC9380
Message 6 of 8
Have you tried replacing the batteries and charging?
If you can take out the existing batteries then as a test you can insert ordinary batteries and see if that powers up the phone  just make sure your remove these batteries and replace with rechargeable before putting on charger
Message 7 of 8
Hi, yes tried that and still same
guess I need to contact Bt now for a replacement
Message 8 of 8
as that has not worked then phone CS 150 or 0800800150 from mobile and ask for a replacement
