Message 1 of 3
BT Home Essentials and remaining on analogue voice
Hello, I'm considering moving from Plusnet to BT Home Essentials. However, I have an analogue telecare system that doesn't work with Digital Voice, so wish to stay on analogue. Is it possible to take BT Home Essentials without also taking Digital Voice?
2 REPLIES 2
Message 2 of 3
Re: BT Home Essentials and remaining on analogue voice
Message 3 of 3
Possibly, possibly not, but you will have to bite the bullet in the next 2 years anyway as the analogue PSTN will be switched off in 2025. Your telecare provider should be making provision for that.
