Message 11 of 14
Re: BT advanced digital phone with Alexa
@Joy5
just phone CS 150 or 0800800150 from mobile and request a DV as you have now moved to digital voice.  as @Keith_Beddoe  posted the offer was 2 essential phones or 1 advanced phone (may have alexa) or a DV adapter
Message 12 of 14
Ok - thanks for your help. I’ll contact @imjolly
Message 13 of 14
Message 14 of 14
Thank you! It may well have done but I rang them and got a very successful result! They’re sending me the advanced digital with Alexa plus one additional handset for free as I’ve had such a hard time tracking it down! It’s not on the BT website and if you Google it you only get instructions for use. Weird ….
Thanks though!
