Message 1 of 3
Caller ID only working for landline numbers
Hi
Just been moved across to Digital Voice and found that the CLI is only working for landlines, any mobiles the number does not come through.
When I check MyBT CLI is enabled and it was working before we were switched over (Thursday)
Any help would be much appreciated
regards Steve
2 REPLIES 2
Message 2 of 3
Re: Caller ID only working for landline numbers
Message 3 of 3
Ok I used the chat function and they reapplied caller display - it is now working!
Turning IT off and on again works once again ...
