Message 1 of 5
Can I disconnect or turn of BT Essential Digital Home (Digital voice) phone?
I have recently had my landline switched to Digital Voice and bought BT Essential Digital Home phones (poor sound quilaity btw. Fuzzy and fades in and out). I regularly need to disconnect/silence my phone. I used to just pull the landline phone out of the socket. Is there any way of doing this that doesn't involve fiddling with the volume on all my handsets. Clearly I don't want to disconnect the broadband. (There are other people in the house and even if not it takes time to reboot.)
4 REPLIES 4
Message 2 of 5
Re: Can I disconnect or turn of BT Essential Digital Home (Digital voice) phone?
Message 3 of 5
You can turn off the handset by holding down the end call button
Message 4 of 5
Thank you!
Anonymous
Not applicable
Message 5 of 5
Press & hold the star (*) key to toggle the ringer on/off.
