Message 1 of 13
Can digital voice handle 999 calls in a power cut?
BT have today emailed me to say I will be "migrated" to DV within the next 30 days.  I phoned 0330 1234 150 to ask what would happen during a power cut.  I was told that the new Hub would handle emergency calls during a power cut but normal phone calls would not work unless a battery backup was fitted.  I think I have been given wrong information and that emergency calls will NOT work in a power cut.  What is the real situation?
I am age 80 and live alone in a rural part of Cumbria.  Would I be entitled to battery backup because of my age?  I am already on the electricity company's records as a vulnerable customer.    My existing landline is copper with ADSL broadband.
Peter M
12 REPLIES 12
Message 2 of 13
Re: Can digital voice handle 999 calls in a power cut?
Message 3 of 13
Whoever told you that 999 calls will work in a power cut should be sacked. No calls can be made with DV in a power cut without battery backup.
As far as I'm aware, you should be eligible for a battery backup.
Message 4 of 13
No, you cannot make a 999 call if there is no power to your hub. No power = no broadband = no calls of any kind can be made. Apparently you are recommended to use a mobile phone so if there is a likelihood of a power cut make sure your mobile phone (if you have one) is kept well charged.
FWIW it's disgraceful that BT Customer Service Agents are supplying such completely wrong information. Not only disgraceful but dangerous.
Anonymous
Not applicable
Message 5 of 13
@licquoricewrote:
"Whoever told you that 999 calls will work in a power cut should be sacked."
@Wuggy23 wrote:
"FWIW it's disgraceful that BT Customer Service Agents are supplying such completely wrong information. Not only disgraceful but dangerous. "
Given the quality of information supplied by BT "Guides" regularly reported on these forums, are either of you surprised?
I'm not.
Message 6 of 13
No, not surprised at all but extremely disappointed in the level of knowledge. Not even knowledge, common sense.
Message 7 of 13
Many thanks to those who replied so quickly.  As a retired electronics engineer I was fairly sure that I had been given wrong information - there will be no power coming down the existing copper wires.  I regret I didn't record the name of the person who gave it.  I do have a mobile phone but it doesn't work in the house - I have to climb the hill behind the house to get a signal.
I tried to contact BT via their website but the relevant page seems "to have a technical issue".  I think I would wish to delay the migration to DV - at least until they can assure me I will be able to phone the electricity company during a power cut!
Peter M
Message 8 of 13
I have informed the mods of the dangerously incorrect advice you were given in the forlorn hope that they may be able to trace the 'guide' and educate them.
Message 9 of 13
You could call BT and tell them that you do not wish to be migrated at this time.  They might disagree with you but be insistent and they may put off the move.
If you do not have a mobile phone or there is no signal at your home this may also be a reason not to be switched to Digital Voice at this time.
See the following links regarding Digital Voice.
https://www.bt.com/help/landline/digital-voice--will-my-service-work-in-a-power-cut-
https://www.bt.com/help/landline/digital-voice-migration
https://abilitynet.org.uk/news-blogs/everything-you-need-know-about-bts-digital-voice
Message 10 of 13
Hi @PeterMartinez
I've sent you a private message to see if it's possible to set you up with a battery backup unit and look into this incorrect information that you have been given.
Please take a look at your private message inbox and get back to me.
Chris
