Message 1 of 3
Cancel Digital Voice
I recently changed to digital voice without realising that my landline would not work. I understand the rollout of digital voice is on hold as there is a concern that if there is a power cut the phone will not work. I am disabled and worry that if there is a power cut I will not be able to phone 999. I want to have my digital voice removed and revert back to a plug in landline but cannot find anywhere for advice about doing this. I've tried using the help section on MyBT but this keeps going round in circles, (as usual)
2 REPLIES 2
Message 2 of 3
Re: Cancel Digital Voice
Message 3 of 3
Normally once changed to Digital voice you cannot revert back to previous connection.  did you request the change or were you changing your broadband package?
