Message 1 of 7
Cancelling Call Redirect after moving
After a lot of effort I managed to set up Caller Redirect on my old Landline number when I moved. After 2 months I called BT to cancel it and was assured it had beeen cancelled. However this has month the £10 charge is still on my bill (I have kept my email) and on dialling the old number the redirect is still in place.  Can you help?
6 REPLIES 6
Message 2 of 7
Re: Cancelling Call Redirect after moving
phone CS 03301234150 who should be able to help or try billing team  https://www.bt.com/help/contact-bt/account-and-billing/broadband
Message 3 of 7
The BT billing team handle caller redirect cancellations
Message 4 of 7
I've now called them twice and still the caller redirect has not been cancelled!
Message 5 of 7
Hi @caroandrew,
Thank you for posting. I'm sorry you haven't been able to get the Call Redirect canceled. If you send me your details, I'll be able to do that for you.
I have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
Message 6 of 7
Thanks for sending over the details @caroandrew
That's all been cancelled for you now.
Cheers
David
Message 7 of 7
Thats gret David - thank ou so much for your help with this!
