Message 1 of 4
Confused about what will happen when connected to full fibre
I fear I'm confused and I am looking for some clarity. Fibre broadband is being installed in my area and, when it's up and running I will have it connected directly into my house. While I know this will give my faster speeds and, I assume,means that I will lose my landline, will I have to be signed up to a new deal and router etc before this connection is made? Or will my existing router work on a temporary basis?
3 REPLIES 3
Message 2 of 4
Re: Confused about what will happen when connected to full fibre
@Shepherdess
You would not lose your phone service, it will be moved over to BT Digital Voice.
See https://community.bt.com/t5/Home-phone-including-Digital/Digital-Voice-FAQs/td-p/2207485
Message 3 of 4
Hi, @Shepherdess welcome to the community, when the full fibre network is ready you will need to place an order to upgrade your existing service, as part of the order an engineer visit will be organised to fit the line and equipment.
You will also need to agree to a new deal with a minimum term and will be provided with a Smart Hub 2 if you don't have one already.
Neil
Message 4 of 4
You will have to sign up for FTTP with a new contract. If you currently have a SH2 the LAN port 4 can be switched to a WAN port for FTTP in the hub management interface, just log in with the info on the hub.
