Message 1 of 3
Digital voice issue
Hi, I am long time BT who has been switched to Digital Voice when upgrading broadband.  I can make outgoing calls but no incoming calls are getting through,  As one of the less tech savvy older generation, I have given up reading and re-reading everything and thought it best to ask for help PLEASE 🙂
2 REPLIES 2
Message 2 of 3
Re: Digital voice issue
as long term BT customer then not porting from another ISP so try phoning the FTTP TEAM 08005874787 and they should be able to help  if redirected to CS then hang up and try again bit later
Message 3 of 3
will try thanks. just thought i'd see if i had done something daft first
