Message 1 of 4
Digital Voice Handset
I had the Digital Voice equipment postcard through the door today. When I go to bt.com/dvequipment and enter my home phone number it says that code is already being used.
Any ideas how I can get a code? I've also tried texting the 61998 number and nothing comes back.
I would happily give up any landline, other than I can't get my elderly parents to ring my mobile number!
3 REPLIES 3
Message 2 of 4
Re: Digital Voice Handset
Message 3 of 4
Try phoning CS 150 or 0800800150 from mobile and should be able to order your DV phone
Message 4 of 4
I've managed to resolve the issue. I re-clicked on 'Check' after being told that my phone number has already been used and it brought up a code which I've now used in the shop.
