Message 1 of 3
Digital Voice
Probably been asked before and id find the answer , but,
ive just ordered full fibre, i see digital voice comes with this.
Is my current phone compatible/the engineer will plug my current phone in to enable it with digital voice
Or do i need to buy a new phone/BT will supply and install phone when engineer installs full fibre...?
2 REPLIES 2
Message 2 of 3
Re: Digital Voice
Message 3 of 3
Re: Digital Voice
the FAQ should answer most of your questions.  you should be offered a free DV phone or adapter on change to digital voice  you can phone CS 150 or 0800800150 from mobile and request a free phone or adapter to use your existing phone.  you can also plug your existing phone into socket on back of hub
