Message 1 of 13
Digital Voice
My mother is 98 and really struggling with the modern handset , plus the voicemail now recites the callers number, which takes ages.
BT really need a handset suitable for these customers, as the demographic is the landline users.
Please can we have a way of turning off the voicemail reciting numbers.
12 REPLIES 12
Message 2 of 13
Re: Digital Voice
Why does she not use her previous handset?
Message 3 of 13
Re: Digital Voice
She is but I still feel the new handsets need to be better suited to older customers
Message 4 of 13
Re: Digital Voice
Why would BT produce a different handset at extra cost just to suit a very small minority of customers that can use whatever handset they prefer in any case?
Message 5 of 13
Re: Digital Voice
Are you going to mention the same to all phone manufacturers?
Message 6 of 13
Re: Digital Voice
I was hoping for some empathy here over my elderly mother’s experience,
Message 7 of 13
Re: Digital Voice
When you say “modern handset”, how old was the previous one?
Most old phones will work fine plugged into the phone socket on the back of the hub.  I still use a ten-year-old cordless phone and it works fine with digital voice.  It would have to be really, really old not to work.
Even if it is on an extension, the extension can be connected to the hub phone socket and it should still work with the old phone.  If you want advice on exactly how to do that, let us know.
Message 8 of 13
Re: Digital Voice
BT used to offer accessible phones (Big button being one product range), I think they still offer them but not sure if they are "digital voice" compatible. When you say it reads the number back, is that on every voicemail?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 9 of 13
Re: Digital Voice
The most frustrating thing is that the voicemail reads the number back every time before the message, it would be lovely to be able to turn this off
Message 10 of 13
Re: Digital Voice
If memory serves, you can ask for 1571 to be turned off but you'll need to phone customer services and request it.
If you have your own answer phone, what you can do is go into MyBT and the phone settings then increase the number of rings before it answers.  That ensures your own answer phone picks up first.
