Message 11 of 13
Re: Digital voice problem
At the risk of stating the obvious, I take it you've restarted the router as it needs a reboot to pick up the new settings?
Message 12 of 13
@pc1795
did you use the link I posted then sent email to the consumer email address like I suggested  that should get you some action
Message 13 of 13
Yes - I've restarted the router multiple times before, during and after the long chat with the bot, and tried connecting a different phone as well.  Nothing made any difference.  The bot said there must be a problem with the connection at the exchange, but it couldn't fix this.
