Message 1 of 14
Digital voice without broadband
I am asking on behalf of my 2 elderly sisters-in-law. Neither of them has broadband or any wish to have broadband. Both have health problems , live alone and rely on their phones for help and company. Both are with BT and have been for many years. Nowhere on the FAQS can I find the answer to what do you do if you do not have broadband and are being switched to Digital voice.  The soothing message says we understand not everyone has "this ability" with regard to equipment but it does not explain anymore about not having broadband. Is moving to another provider their only option? Will that even work? Can they opt out of Digital Voice? For that matter, can I? I do not like the sound of being totally dependent on the internet. In view of the big IT outage recently this sounds to me like putting all our eggs in one basket.
13 REPLIES 13
Message 2 of 14
Re: Digital voice without broadband
I myself was moved to digital voice last September and the phone has worked exactly as it did before ever since.
I’m perhaps not the best person to answer your questions.  There are more knowledgeable people on here but as no one else has done so, I’ll try to give you some answers.  I’m sure I’ll be corrected if I’m wrong.
In reverse order:
The recent outage was more an industrial thing and hyped up by the media.  Myself, (and I’m sure the vast majority of ordinary users), did not even notice.  Certainly, there was no disruption to digital voice that I was aware of.  The biggest problem is that it will not work during a power cut.  Whether that’s a problem depends on where you live and how often you get power cuts, of course.  It is possible to get a battery backup for it.
Can they opt out is a little more difficult to answer.  I believe BT will not proactively move anyone against their objections but the reality is that the old phone system is obsolete, falling apart and becoming difficult to get spares for, as no one makes them anymore.  Eventually, everyone will have to move, if you still want some sort of phone service.
Moving to another provider is a waste of time.  This is not just a BT issue, although they’ve taken most of the flak for it.  The same situation applies to all of them.  Sooner or later, they will all go the same way.  At least BT have provided some sort of alternative solution.  A lot of providers are not providing a phone service.
As I understand it, essentially, they won’t have “the internet”.  What they will have is a box that plugs into a power point.  The phone then plugs into that box and the box plugs into the phone socket.  It should work on the defaults and be no more difficult to setup than changing a light bulb.
Message 3 of 14
Phone only customers without broadband will be the last customers to be moved to Digital Voice and probably won't be until 2027.
By that time, a definitive solution will be in place but will probably consist of a low bandwidth box to plug a normal phone into as described by @WSH  or it may be the 'box' is simply provided at the exchange and the phone will work as now as far as the customer is concerned.
Message 4 of 14
Thank you. That is re-assuring.
Message 5 of 14
Thank you. I did not understand they would not need to pay for broadband they would never use. If there is a magic box to get round the problem then we are sorted.
Message 6 of 14
"By that time, a definitive solution will be in place but will probably consist of a low bandwidth box to plug a normal phone into as described by @WSH or it may be the 'box' is simply provided at the exchange and the phone will work as now as far as the customer is concerned."
That's interesting - if the box is indeed provided at the exchange then presumably it could be backed up by batteries in the same way that the old analogue system is/was. That would remove the objection from some people that DV phones won't work in a power outage.
Message 7 of 14
Yes, that thought occurred to me.  Fewer exchanges will be needed for FTTP, however and I'm not sure how it tallies with most of the exchanges facing closure in the long term.  As fibre can travel further, it might even help to have fewer but better provisioned centres?  We will have to wait and see.
Message 8 of 14
The ATA in the exchange solution would only be for copper connections, not fibre.
Message 9 of 14
So presumably, with exchange closures, distance would be a limiting factor then?
Message 10 of 14
How is a voice only line provided by BT in a fibre only home?
