Message 1 of 3
Digital voice
I currently have normal landline with 1 main phone plugged into socket and 2 further phones that connect to the main phone without a phone socket, so how will this work with digital voice?
TIA
2 REPLIES 2
Message 2 of 3
Re: Digital voice
When you get digital voice and SH2 you connect the cordless base station to the phone socket in back of SH2  there are numerous posts in the forum about this just use search for more help
Message 3 of 3
Re: Digital voice
As has been said if you have cordless phones, just plug the base station into the phone socket on the back of the router.
If you have extensions connected via the house wiring, then you can get BT Digital Voice Adapters into which you can plug your existing wired phones. Each one plugs into a mains socket and has a phone socket. You can then send and receive calls as normal on these former extensions. BT will supply one of these for free if you ask for it and otherwise they currently cost £20 each.
