Message 1 of 5
Digital voice
I am changing to digital voice are my bt3110 handsets compatible
4 REPLIES 4
Message 2 of 5
Re: Digital voice
Message 3 of 5
Re: Digital voice
@Bigmally64
Yes, you just need to plug the base unit into the green phone socket on the back of the new BT Smart Hub 2.
Message 4 of 5
Re: Digital voice
or register directly with the hub.
Message 5 of 5
Re: Digital voice
When registering the phone to the SH2 DECT base station you may well find you do not have all the phone facilities you had previously and better connecting the base to the phone socket on back of SH2
