Message 21 of 25
Re: Eero 5 BT Hub and Digital Voice!
Many thanks, I had this previously - are the TP links likely to be better? Fonowt WiFi Booster ?
To be honest the house is fine for us, netflix occassionally slows down but it's mainly for my son in the one bedroom, I assume I just purchase additional plus if I need them
Message 22 of 25
Wi-Fi boosters are a waste of money, but you should be able to add an additional TP Link PLA, which has wireless, as they all work to the same standard.
Message 23 of 25
So as well as using what you've suggested I could add a wireless PLA which would also help to boost signal?
Message 24 of 25
All is explained in the link I posted. Click on 'what is powerline' on the webpage.
Message 25 of 25
If there's more than one consumer unit, powerline adapters may not work. So the garage might have a lot to do with things if there's interesting electrics. But your main point is not correct as virtually everyone has a single feed to the house - it's what happens after the main CU that is important.
I have a hybrid with Eero covering the main mesh network for the house, but have a wired backhaul, with one Eero attached to a powerline adapter for one room, on the same consumer unit. Generally Eero mesh is fantastic though. But you cannot fight against physics - thick walls are thick walls.
