Message 11 of 25
Re: Eero 5 BT Hub and Digital Voice!
Thanks so much for your help. The only concern I have is that it states the house has to work on the same powerline, our garage was converted by previous owners - no idea whether that means it operates on the same powerline or not! I find the wifi fine for what we need and sky have sorted upstairs with a sky booster I believe it's just my son's gaming that's the issue!
Message 12 of 25
What has the garage to do with it?
Powerline adapters normally work provided you only have a single mains feed to the house, which is normally the case, unless people have a separate annex with its own mains feed.
The XBOX can be connected to one of the Ethernet ports on the PLA, eliminating the wireless connection totally.
Message 13 of 25
Sorry our main port for the bt hub wifi is in the converted garage which is actually part of the house
Message 14 of 25
So for me to understand, the PLA is what I'd be purchasing - one would be connected to the BT hub and I'd simply put another in my son's room connected to the Xbox? Is it likely we'd need another in between to help extend the wifi?
Message 15 of 25
That is correct, one plugs into the mains socket near the home hub, and is connected via a short Ethernet cable.
The other end is plugged in next to the Xbox, and another short Ethernet cable goes from that unit, to the LAN port on the Xbox. Wireless is not involved with this connection, but the PLA will transmit wireless, so you may find it covers the rest of the house, without any more units.
The Xbox will work better if its not relying on a wireless connection.
The Euro 5 relies on a wireless connection between the units, and will most likely struggle to work if there is a poor signal in the affected room. They are not the best solution in that case.
Message 16 of 25
Thanks so much so would this package be suitable in your opinion? I'm sure I'm able to return the eeros anyway as purchased on amazon.
TP-Link TL-PA9020PKIT 2-Port Gigabit Passthrough Powerline Starter Kit, Data Transfer Speed Up to 2000 Mbps, Ideal for HD Video Streaming and Online Gaming, No Configuration Required, UK Plug
Message 17 of 25
Sorry for all the questions so for example if we're using an extension lead at present we'd put the PLA into the main socket and add the extension into the PLA?
Message 18 of 25
Yes, that would be the correct way to do it.
The item you pointed out, does not transmit wireless as well.
Message 19 of 25
Thank you and do you know if this is the best version? TP-Link TL-PA9020PKIT
Message 20 of 25
This one is cheaper TP-Link TL-PA7017P KIT £37.49
Assuming you do not want extra wireless coverage.
