Message 21 of 25
Re: Emergency Welfare
@idw1
Probably within this group so would be BT. Follow the advice posted by @RobbieMac  although I am sure you said you had tried that. I assume she is not on BT Digital Voice, where her phone is plugged into the back of her home hub?
1869 32 Allocated BT 4+6 15/07/1994
1869 33 Allocated BT 4+6 15/07/1994
1869 34 Allocated BT 4+6 15/07/1994
1869 35 Allocated BT 4+6 15/07/1994
1869 36 Allocated BT 4+6 15/07/1994
Message 22 of 25
That was where I started some hours ago
Message 23 of 25
But I'll have another go.
Message 24 of 25
 Option 2 - they sent me a text and hung up.  Every time I reply to this text the system gets in a tangle then starts again.
Message 25 of 25
Thanks for trying that @idw1
Sorry you're having so many problems getting the fault reported.  Message me privately and I'll pick up and get back to you.  Click into my profile from my username and you'll see the envelope to message me privately in the top right hand corner.
Thanks,
Robbie
